![]() | Float Array Fill | Fills a float array with a specific numeric value. |
![]() | Float Array Offset | Adds a specific value to every float array entry. |
![]() | Float Array Analysis | Analyses a float array and provides some characteristic values. |
![]() | Integer Array Analysis | Analyses a integer array and provides some characteristic values. |
![]() | Array Indexer | Provides access to individual array elements. |
![]() | Array Mixer | Mixes up individual arrays. |
Length | Length of the array. |
Valid Length | Number of entries up to the very first NaN value (only for Float). |
Min | The minimum value in the array. |
Max | The maximum value in the array. |
HasPositive | At least one value is higher than zero. |
HasNegative | At least one value is lower than zero. |
HasZero | At least one value is zero. |
IsNull | True if no float array is bound to the Input property. |
The Array Indexer node provides access to individual elements of an array or to a range of elements. This node is the equivalent to the Array node.
The type of array and the number of elements which should be accessed have to be specified when the node is dragged to the Content Editor. Allowed types are the same as in the Array node. The individual array elements are available as output properties (Value_0000 etc.). The NewArray property also provides these values as an Array property. The event Changed is fired if one of the output properties has changed.
The input property IndexStart defines at which index in the source array the reading of the elements should begin. If the last elements in the source array are reached and there are not enough elements to fill all outputs of the Array Indexer, the remaining outputs are set to zero.
The Array Mixer is able to perform Insert, Remove and Overwrite operations on an incoming Array.
The type of array which should be modified has to be specified when the node is dragged to the Content Editor.
The initial array content, on which the operations are performed, is specified by the BaseArray property. AutoReset specifies if the output property ResultArray should be reset to BaseArray if the scene is loaded. A manual reset can be triggered by the Reset method. Note that all operation are cumulative and change the active array. All further operation are performed on the modified array!
To insert values to the active array one has to specify the InsertArray, the InsertIndex
at which the insertion begins and trigger the Insert method. If the insertion index is larger than the length of the current ResultArray, nothing is inserted!
