Web Browser
The Web Browser node renders web pages into a texture so their contents can be used inside a Ventuz scene. This is done based on the Webkit/Chromium technology, the former being the basis for the majority of modern web browsers on the market. The node supports HTML as well as Adobe Flash and Microsoft Silverlight content.
Usage and Interaction
By default, the Web Browser node will take a URL and render its content onto a texture. As an alternative, the NavigationMode property can be changed from URL to HTML to render the content specified in the HTML property. In both cases, the resulting texture is provided by the Texture output property and can be used same as any other texture in Ventuz. The resolution of the texture (which is also used as the virtual window resolution passed to the browser layout engine) can be specified with the WebBrowserHeight and WebBrowserWidth properties. If both are zero, the size of the Renderer Window will be used instead. WebBrowserAutoMipMap autogenerates mipmaps for improved rendering quality. However, this may cost some performance and is not supported by all graphics cards. Zoom can be set to a percentage between 10% to 500% to influence how the layouting is done (i.e. change the font size, ...).
The TransparentBackgroung property controls whether the web view background has a default color or is transparent.
Same as the other interaction nodes, the Web Browser node has an implicit behavior which causes the node to actually use the texture instead of just generating it. If the ScreenAligned property is set, the Web Browser node will act similar to an Overlay Rectangle and render the texture as a 2D fullscreen overlay. When deactivated, the node will instead act similar to a Texture Node, activate the texture in the render engine and thus cause subsequent geometries to be rendered using this texture. The implicit behavior can be disabled altogether by deactivating the BehaviorApply property.
Similar to the Touch Paint node, the ScreenAligned property will also influence how mouse/touch input is mapped to the browser window. In screen-aligned mode, the browser output directly matches the renderer window so the touch coordinates are directly mapped to the virtual browser window. When used in object-mode (= non screen-aligned), both the geometry under the Web Browser node and the orientation of the world space at the Web Browser node become relevant:
Independent of the actual geometry, the node will calculate the intersection point between a ray from the camera position through the touch position and the X/Y-plane at the hierarchy position of the browser node. To be more precise, the point -0.5/0.5/0.0 will be mapped to the upper left corner and the point 0.5/-0.5/0.0 to the lower left corner of the virtual browser window. This exactly matches the geometry of a Rectangle node with its default parameters.
Input
The Web Browser Node accepts Keyboard, Mouse and Touch input to interact with the rendered content. The position of the mouse cursor and state of the left mouse button are actually transmitted to the Web Browser node as a virtual touch to ensure consistent behavior between mouse and touch input. When LocalMouse is enabled, the browser will receive additional mouse information (such as mouse wheel movement) that a touch cannot represent. Since this information is independent of the MultiTouch subsystem, it will be transmitted to all browser instances that have the LocalMouse property enabled.
Code Description
13 Return
9 Tab
8 Backspace
127 Delete
27 Escape
The pass an integer value as part of the method invocation, either the output event of a Script node or an Event node has to be used. For the latter, the value can be specified in its Argument property.
Browser Functionality
Progress and Status
Due to the complexity of a browser layout engine and many ill-formatted HTML sites on the internet, it is to be expected that the browser will crash at one point or the other. If the complete browser has crashed, the Crashed event is fired. If just one of the plug-ins (Flash/Silverlight) has crashed but the browser is still operational, the PluginCrashed event is fired instead. The most common example is a video player written in Flash crashing while the actual browser (scrolling, navigation, ...) still works. Call Recover to create a new instance of the browser. The web browser does not recover automatically from a crash, because this could end up in an infinite recovery loop. The user should decide when (and if at all) to recover a crashed web browser.
Flash and Silverlight
Flash and Silverlight are two popular media formats for rich internet sites. Both of these can be rendered by the Web Browser node if the respective plug-ins are installed on the system. Installers can be downloaded at:
Adobe Flash and Microsoft Silverlight have direct system access that circumvents Ventuz. If for example a Flash embedded video goes to fullscreen, Windows will have Ventuz drop out of fullscreen mode. Similar, a Flash content can manipulate the sound device which may disrupt correct operation of Ventuz. Beware of Flash/Silverlight content that uses hardware resources.
Adobe Flash and Microsoft Silverlight are the only plugins officially supported. A common problem with other plugins is that they open up their own window when used from Ventuz.
Outputs
The Web Browser node provides a large number of outputs that can be used to react on what the user is doing inside the browser. For the touch output properties, see the Touch Button documentation.
Content
Cursor
0 Pointer (default)
1 Cross 2 Hand 3 Ibeam 4 Wait
41 Custom
JavaScript
The Web Browser node supports the JavaScript scripting language both as part of the content as well as as a means of interaction between Ventuz and the site content. This is done by defining input/output properties, methods and events in the Custom Model editor at the bottom of the Property Editor.
Methods/Events
<html>
<head>
<title>Method Test</title>
</head>
<body>
function CalculateSquare(value) {
  var result = value * value;
  document.write("The square of " + value + " is " + result + "<br>");
  ventuz.Result(result);
</script>
</body>
</html>
Properties
Ventuz properties can also be connected to the script code via the Custom Model. They become available as members of the global ventuz object. Changes in the input properties are automatically reflected in the script code but updating outputs has to be explicitly triggered inside the script code by calling the function ventuz.updateOutputs().
<html>
<head>
</head>
<body>
function CalculateSquare() {
  ventuz.result = ventuz.value * ventuz.value;
  document.write("The square of " + ventuz.value + " is " + ventuz.result+ "<br>");
  ventuz.updateOutputs();
</script>
</body>
</html>
Execute On Load
Example 1:
Example 2:
Limitations
As with any technology as complex as a web browser, there are certain limitations one has to be aware of. The most important one concerns MultiTouch input.
Although the Web Browser accepts MultiTouch input, the underlying technology works based on mouse input. So only one touch is used and none of the gestures implemented in the browser variants of MultiTouch devices is supported at this point.
Other known limitations which may or may not be relieved in the future include:
As of Ventuz4, the browser node is available in the 64bit version of Ventuz.
