Random Points | This node provides random point clouds of different shapes. |
In order to make the Points visible a Color Node must be added before the Random Points Node. If a Material Node is used the Emissive color must be activated. An ambient lighting makes the Points visible as well. This is different to the behavior of the other geometry nodes because the Points do not have any surface.
For ways to change how the individual points are rendered, see Point Options.
