Ventuz will run on any graphics card that fully supports Direct3D 9.0c under Windows 7 or higher.
![]() | AMD | FirePro Series (recommended) Radeon Series (with limitations) |
![]() | Nvidia | Quadro Series (recommended) Geforce Series (with limitations) |
The NVIDIA Quadro Digital Video Pipeline is currently not supported by Ventuz. The SDI output of these board family can be used as monitor output. External key, Audio and other features of this product line are not address by Ventuz.
![]() | Intel | Intel integrated graphics |
![]() | Direct3D | Windows 7 compatible graphics board |
Feature summary:
Series audio k+f keyer multi multiformat bypass dual link 3G 4k Timecode AFD Specials DELTA-HD yes yes5 no yes timebase no no no yes8 yes yes DELTA-3G yes yes5 no yes timebase no yes2 A & B yes8 yes yes DELTA-KEY yes yes5 yes yes timebase yes no no no yes yes key-delay, key-input, softkey Centaurus II3 yes yes yes4 yes full yes yes no no yes yes softkey Atomix3 yes yes no yes full yes yes A & B no yes yes softkey Blackmagic Decklink yes yes5,12 yes1,4,12 depends6 no no yes2 B bm7 yes no Blackmagic UltraStudio yes yes5,12 yes1,4,12 depends6 no no yes2 B bm7 yes no VisionAV-SDI no no no no no no no A & B no no no AJA Corvid 88 yes yes (4k)11 yes yes10 no no no A yes8 9 no no AJA Kona 3G / Kona 4 yes yes yes yes10 no no no A yes8 9 no no AJA Kona LHe+ yes yes yes yes10 no no no A no9 no no AJA Kona LHi yes no no yes10 no no no A no9 no no
Limitations:
![]() | Deltacast | Delta-HD series Delta-3G series Delta-Key series |
Ventuz 4.06.00 uses Deltacast SDK 5.17, supporting the following deltacast products:
Currently not supported are:
Matching Deltacast Drivers with Ventuz Versions
For Deltacast boards, the driver version must match the SDK version perfectly. Use the drivers that are installed in the Ventuz directory, usually at "C:/Program Files" in English windows installations.
The fitting Deltacast Drivers are bundled with Ventuz. For reference, here is a table that matches Ventuz version, Deltacast SDK version and the driver version as displayed in the device manager. A different driver version will be displayed for the Gen1, Gen2 and DVI boards, fortunately they are easy to discern:
Ventuz | Deltacast SDK | HD/Gen1 | 3G/Gen2 | DVI | Note |
4.00.00 | 5.13 | 5.4.79.0 | 1.0.44.0 | 5.3.24.0 | |
4.01.00 | 5.14 | 5.4.91.0 | 1.0.71.0 | 5.3.28.0 | |
4.04.00 | 5.15 | 5.4.112.0 | 1.0.125.0 | 5.3.36.0 | |
4.05.00 | 5.16 | 5.4.121.0 | 1.0.138.0 | 5.3.41.0 | |
4.05.02 | 5.16patch | 5.4.124.0 | 1.0.138.0 | 5.3.41.0 | Ventuz 4.05.02 is also compatible with the unpatched 5.16 driver. |
4.06.00 | 5.17 | 5.4.125.0 | 1.0.151.0 | 5.3.42.0 | |
4.08.00 | 5.19 | 5.4.133.0 | 1.0.230.0 | 5.3.47.0 | There is no official 5.18 SDK |
5.0.0 | 5.19 | 5.4.133.0 | 1.0.230.0 | 5.3.47.0 |
4k modes
The following boards support 4k modes:
Deltacast uses four HD or 3G links to transport a quarter of the image each. These links are ordinary SDI signals without any additional hidden tagging, swapping two of the links will swap the quarters of the image.
It is not recommended to use two boards and implement keying using one board as input and the other as output.
DELTA-Key
If there is trouble with a Deltacast keyer if genlock is set to Internal, program the genlock manually to the input port of the background signal or external reference! (Ref)
Memory Preallocation
Sometimes, initializing Deltacast boards will fail with the following error meessage:
Starting video stream failed. Sometimes this can be fixed by setting Deltacast specific registry keys for 'memory preallocation'
This is a problem with Deltacast drivers on Windows Vista, Windows 7 and Windows 8.
download this registry file from www.ventuz.com
![]() | DVS | Centaurus II (LT) Atomix series |
DVS boards have been designed for very reliable and stable video IO between the SDI and PC worlds.
Centaurus II
Atomix Series
![]() | AJA | Kona / Corvid |
The Corvid 88 is unique as it allows to output a 4K 60Hz stream with key and fill.
The small boards LHe+ and LHi only support one stream with audio.
The required flash program can be downloaded at our web page. After the end of the flashing process, the software will ask you to power down your computer. You really must power down your computer, or the update will no take effect.
![]() | Datapath | VisionAV-SDI VisionSC-SDI |
The VisionAV-SDI can capture a single channel SDI signal. Currently we do not support audio with Datapath boards.
![]() | Black Magic Designs | Decklink series UltraStudio series |
Blackmagic Design provides several (cost-effective) solutions for SDI output (Fill+Key). The boards have been designed for connecting a tape deck to a PC for recording and playback to tape. Therefore, the product name is Decklink and the boards can either output or input SDI signals - but not both.
Some of the Decklink boards have an internal keyer hardware on-board which make them a cost-effective solution for downstream applications. Please note that Decklink boards do not provide any watchdog or power-fail options!
The latest models, the Decklink Extreme 4K and the UltraStudio 4k, are capable of independent input & output. (Ref)
![]() | Deltacast | Delta-DV series |
![]() | Datapath | VisionRGB VisionAV VisionSC |
Datapath have developed a sizeable portfolio of capture cards providing HD video capture or HDMI capture capabilites as well as a number of high resolution video capture modes.
Ventuz supports the Vision-AV and Vision-SC series, including the VisionSC-HD4+ board.
As of Ventuz 4.04.00 the input source can be selected in the AV configuration. Only one input can be used at a time.
![]() | NewTek | Tricaster series |
![]() | Off-Screen |
This is rendered to an invisible buffer on the GPU. The purpose of this is to transmit this buffer to the Ventuz Director or other applications, to display a preview of the rendering pipes.
![]() | Windows Media Foundation |
