![]() | Value Switch | This node passes one of a number of input values to the output. All input values have to be of same type. |
![]() | Multi Switch | This node processes multiple inputs and passes the result to the output. One can handle multiple input groups with a single index. |
The Value Switch Node is the equivalent of the Switch Node for the scene Content. It is used to switch between the values of the Value input properties based on the Case property. Input Value properties can be added/deleted with the methods at the bottom of the Property Editor or in the context menu of this node. Please refer to the Switch Node for more information.
Single, Integer, Boolean, String, Event, Texture.
The + and - buttons on the bottom of the property window add and remove additional input values to all groups. All groups of a Multi Switch Node have the same number of input values.
All types | Last Changed | The output value is always the last changed value of the input group. |
Integer/Float | Sum | The sum of all input Values. |
Min/Max | The minimum/maximum input value. | |
Average |
The average value of all input values. | |
Boolean | AllOn/AllOff | Output is true if all input booleans are true/false. |
AnyOn/AnyOff | Output is true if at least one input boolean is true/false. | |
SingleOn/SingleOff | Output is true if exactly one input boolean is true/false. | |
String | Concat | The concatenation of all input strings. |
Longest/Shortest | The shortest/longest string. | |
FirstNonEmpty | The first string by index that is not empty. With FirstNonEmptyTrimmed all leading and trailing whitespace characters of that string are removed. | |
Texture | First Valid | The first valid texture by input index. |
