![]() | Mover | This is a multi-purpose node for generating values within a specific range. |
![]() | Alternator | This node alternates values by true or false. The duration of each state can be specified. |
Function defines the mathematical function used by the Mover to calculate the values in one period. The duration of a single period is defined by the Duration property. The Sine and Cosine functions result in smooth ease-in and ease-out animations. The Linear function produces constant animations, whereas the Alternator mode switches between Min and Max values. The Random function produces random values within the specified range - one new value in each period.
Enabling Swing will produce a continuous and smooth curve. In the modes Alternate and Random the Swing property has no effect.
Immediately upon completion of one period, the OnRepeat event is fired and a new period begins.
