![]() | Rectangle | A flat, rectangle shaped mesh primitive. By far the most frequently used geometry in a typical Ventuz scene. |
![]() | Rounded Rectangle | Similar to Rectangle but each corner individually can be made either rounded or sharp. |
![]() | Gradient Rectangle | Similar to Rectangle but can be assigned two color values to create a resolution independent gradient. |
![]() | Overlay Rectangle | Special rectangle that is always screen-aligned and fits the size of the output. |
Used for mouse interaction, see HitTest and MouseOver nodes.
The Overlay Rectangle is not a rectangle geometry in the way of the other three rectangles. It does not create some form of rendering mesh that can be positioned in 3D space. Instead, it is specially designed for the case where the user wants to map a texture to the whole screen. This can be either a texture loaded from a file, generated by a RenderTarget or any other source that generates a texture. Common cases of usage are adding a nice background to a scene which is independent of the 3D geometry or mapping a movie to the complete screen. As an alternative, the Viewport/Backgound Node can also map a texture to the whole screen but offers additional stretch behaviors.
The Overlay Rectangle ignores all Color and Material node settings and is always rendered in white.
The Overlay Rectangle does not perform any depth testing and neither reads from nor writes to the Z-Buffer. It provides a property AlphaMode for simple selection of the alpha blending used to render the overlay. There are five different presets:
Value | Description | Source Factor | Dest Factor | Function |
No Setup | The Overlay Rectangle does not change any alpha blending setting. The current settings of any previous Alpha Blending node will be used. | - | - | - |
Alpha Blended (default) | The default alpha blending is used. Texture applied on the Overlay Rectangle uses their alpha to perform normal transparency. | Source Alpha | Inverse Source Alpha | Add |
Additve | All pixels are added to the background. This mode is useful for effects such as glow and lens flares. | One | One | Add |
Overwrite | All pixels overwrite the background. Pixels with alpha value 0 may not be drawn due to the Alpha Testing. | One | Zero | Add |
Premultiplied Alpha | Useful if the texture applied on the Overlay Rectangle contains premultiplied alpha. This mode is often used if the texture is a Render Target. | One | Inverse Source Alpha | Add |
