![]() | Touch Translation | Single touch gesture to translate an axis. |
![]() | Touch Rotation | Single touch gesture to rotate around an axis. |
![]() | Touch Transformation | Two-touch gesture to translate, rotate and scale at the same time. |
These three interaction nodes form the set of transformation gestures. They operate in an object-based fashion so to activate them a touch has to hit a mesh/font/volume that is part of the subtree spanned by the interaction node. At first glance it might seem an unnecessary duplication to have dedicated translation and rotation nodes when the Touch Transformation can handle all of these transformations. However, they all are custom tailored to special use cases and achieve different effects.
Use for: Slot machine style wheels, volume knob style elements, stearing wheel, ...
