Template Port | This node provides access to the Template Engine from within the scene logic |
Count indicates the amount of takes available, if no or an invalid Data is set the property shows the default value 0. Current shows the current state of the template -1 means that a template is cueing. Duration provides the duration of the transition from the present template to the next one.
Descripton gives the user defined description of the template.
