A Ventuz system (or machine) can broadcast its signature across the network to help control software finding other machines. If enabled in the Machine Configuration, an OSC Bundle is send periodically to the specified multicast IP address. All systems which are able to receive such UDP multicast packets can receive these bundles to find all Ventuz machines.
OSC Address | /VENTUZ/MachineID |
default IP addr | Multicast 225.225.225.1 |
default IP port | 19299 |
default interval | 2 seconds |
with these arguments:
Arg Index | OSC Type | .NET Type | Description |
0 | i | Int32 | Signature Version (1) |
1 | s | String | Machine Name (no Unicode support in OSC) |
2 | i | Int32 | Group ID |
3 | i | Int32 | Machine ID |
4 | T F | Boolean | True: Ventuz Designer False: Ventuz Presenter/Runtime |
5 | i | Int32 | CLI Remoting IP port number, 0 if disabled |
6 | i | Int32 | .net Remoting IP port number, 0 if disabled |
7 | i | Int32 | Miranda/Vertigo Remoting IP port number, 0 if disabled |
8 | i | Int32 | OSC Remoting IP port number, 0 if disabled |
9 | i | Int32 | Number of IP addresses following from argument 10 |
10+ | s | String | IP Address of the Ventuz Machine |
class Ventuz.Kernel.Remoting.MachineSignaturReceiver : Component, IDisposable, ISupportInitialize
The component continuously listens to the default UDP multicast address and port for any Ventuz Machine Signatures. All received signatures are stored in an internal cache and the user gets notified if a new signature has been received. If a certain signature has not been received for more than 5 seconds, it gets removed from the cache. The MachineSignaturReceiver provides two events for these notifications: SignatureReceived and SignatureExpired.
The actual machine signature is managed by the MachineSignatur class which offers simple read-only properties to access the data.
