View | ||
![]() | Pan | |
![]() | Scroll vertically | |
CTRL ![]() | Scroll horizontally | |
Selection | ||
click ![]() | Node | Select Node with children |
CTRL click ![]() | Node | Add Node without children |
SHIFT click ![]() | Node | Add Node with children to selection |
CTRL + SHIFT click ![]() | Node | Add Node without children to selection |
UP | selected Node | Select upper sibling Node |
DOWN | selected Node | Select lower sibling Node |
LEFT | selected Node | Select parent Node |
RIGHT | selected Node | Select first child Node |
Editing | ||
CTRL + X | selected Nodes | Cut selection to clipboard |
CTRL + C | selected Nodes | Copy selection to clipboard |
CTRL + V | selected Node | Paste from clipboard below |
CTRL + V | no selection | Paste from clipboard |
DELETE | selected Nodes | Delete/Unlink selection |
SHIFT + DELETE | selected Nodes | Unlink selection |
click ![]() | Node | Show context menu |
click ![]() | Node | Collapse/Expand children |
CTRL + L | selected Nodes | Collapse/Expand children |
CTRL + A | selected Nodes | Toggle Inactive state |
CTRL + B | selected Nodes | Toggle Blocked state |
CTRL + R | selected Nodes | Set Render Point |
Naming | ||
double ![]() | Node | Edit name |
F2 | selected Node | Edit name |
ENTER | name editing | Confirm name edit |
ESC | name editing | Cancel name edit |
Annotations | ||
CTRL + E | selected Node | Edit Node Annotation |
CTRL + E | no selection | Edit Container Annotation |
double ![]() | Annotation | Edit Annotation |
![]() | Annotation | Drag Annotation |
![]() | Annotation border | Resize Annotation |
ESC | Annotation editing | Cancel edit |
click ![]() | Annotation editing | Confirm edit |
click ![]() | Annotation X | Delete Annotation |
empty annotation | Annotation editing | Delete Annotation |
Containers | ||
double ![]() | Container arrow | Navigate into Container (down) |
click Navigate Next | over Container | Navigate into Container (down) |
CTRL + D | selected Container | Navigate into Container (down) |
double ![]() | Container root | Navigate one Container level up |
click Navigate Back | free area | Navigate one Container level up |
CTRL + U | Navigate one Container level up | |
click ![]() | free area | Select current Container |
click ![]() | free area | Show Container overview |
CTRL + M | selected Nodes | Merge selection to new Container |
CTRL + SHIFT + L | selected Container | Seal/Unseal Container |
CTRL + SHIFT + E | selected Container | Externalize Container |
CTRL + SHIFT + X | selected Node | Expose Icon to upper level |
Drag&Drop | ||
![]() | selected Nodes | Drag selection |
![]() | selected Nodes | Drag selection special |
Drag&Drop Hierarchy Nodes from same or other Scene, Repositories or Toolbox | ||
drop | Drop-Target (arrow) | Copy/Move |
drop | Interface Container | Exchange if dragging an Interface |
drop special | Drop-Target (arrow) | Special operation |
SHIFT drop | Drop-Target (arrow) | Move |
CTRL drop | Drop-Target (arrow) | Copy |
CTRL + SHIFT drop | Drop-Target (arrow) | Link |
CTRL + ALT drop | Drop-Target (arrow) | Reference Copy |
All drop operations for Nodes allow to stamp Nodes to the drop target multiple times by clicking ![]() ![]() | ||
Drag&Drop Properties or Methods from Property Editor | ||
drop | Node | Show sources popup (Binding) |
hold ![]() | Node | Select Node |
hold ![]() | Container arrow | Navigate into Container (down) |
