![]() | Value Switch | This node passes one of a number of input values to the output. All input values have to be of same type. |
The Value Switch Node is the equivalent of the Switch Node for the scene Content. It is used to switch between the values of the Value input properties based on the Case property. Input Value properties can be added/deleted with the methods at the bottom of the Property Editor or in the context menu of this node. Please refer to the Switch Node for more information.
