![]() | Float Array Fill | Fills a float array with a specific numeric value. |
![]() | Float Array Offset | Adds a specific value to every float array entry. |
![]() | Float Array Analysis | Analyses a float array and provides some characteristic values. |
The Float Array Processing nodes perform various operations on or extract information from Float Array Nodes.
Since for now the only sensible application for the Float Array Processing Nodes is for Chart processing, they are listed as children of the Chart Node and not as items in the Logic Toolbox category. To access them, right click on the Chart item in the Geometry category.
Length | Length of the array. |
Valid Length | Number of entries up to the very first NaN value. |
Min | The minimum value in the array. |
Max | The maximum value in the array. |
HasPositive | At least one value is higher than zero. |
HasNegative | At least one value is lower than zero. |
HasZero | At least one value is zero. |
IsNull | True if no float array is bound to the Input property. |
