![]() | Image Metadata | This node reads different metadata formats from images and provides this data as an XML document. |
Some image formats have the ability to embed meta-data which contains information about the photographer, the camera, date and time when the image was shot etc. This information can be accessed via the Image MetaData node if they are in a supported meta-data format. The node provides these information as a XML document.
The input properties of this node are: File specifies the image. If the AutoUpdate property is enabled, Ventuz will reload the image and re-read the meta-data. The properties in the Metadata Format category specify which formats should be included in the resulting XML output.
The output property ContainsMetadata indicates if the image contains any meta-data. XmlDoc provides the meta-data as an XML document which can be navigated with the XPath Expression node
