Expressions
Expressions Nodes can combine multiple input properties, perform numeric/string operations on the inputs and provide the result as an output property. They can be thought of as mini C# sharp functions and follow the C# syntax. The number of inputs can be adjusted by using the Custom Model.
A Float Expression with four input properties and the expression EXPRESSION is internally roughly translated to something like the following:
using System;
   return EXPRESSION;
The expression must therefore be a single statement that evaluates to the target type. For example, it is not possible to use the if-keyword in an expression but an inline if
is valid. Since the System namespace has been made available, all functions in the  Math Namespace, the Convert Class and all  String operations are supported. The Expression Nodes have been designed for simple operations only. To avoid their limitations, use the Script Node instead.
Examples
